Finally Arrived!
Finally Arrived!
25.07.2022, 19:25
(25.07.2022, 17:01)TrafGib schrieb: Good to know. Appears to be a worthwhile, and safer, investment. Among the many users, has a preferred brand of aftermarket lines surfaced?
No one here has ever had to report a burst brake line on an SRX due to age. So you can take it easy there. A well vented brake system brakes excellently even with the old rubber lines and as long as they are not cracked I would not have any concerns. The advantage of Stahlflex is the harder pressure point at the pump, because the line can not stretch. Who puts value on original remains with the lines of anno 1986.
In any case, however, worth the complete disassembly of the brake system with cleaning and rebuild. As a rule, no new rubbers for brake pump and calipers must be purchased as long as they are still in perfect condition. I then also always convert the System to silicone DOT5 brake fluid. Only those of Schöbel or "Mike Sanders". With BelRay the rubbers swell.
cheers Chris
  • TrafGib
Finally Arrived! - von TrafGib - 23.07.2022, 17:41
RE: Finally Arrived! - von Peter-D - 23.07.2022, 18:38
RE: Finally Arrived! - von TrafGib - 23.07.2022, 19:15
RE: Finally Arrived! - von wergan - 23.07.2022, 20:54
RE: Finally Arrived! - von TrafGib - 24.07.2022, 16:51
RE: Finally Arrived! - von Peter-D - 24.07.2022, 18:47
RE: Finally Arrived! - von Jörg Dümpelmann - 24.07.2022, 20:20
RE: Finally Arrived! - von TrafGib - 25.07.2022, 17:01
RE: Finally Arrived! - von LucaGregory - 25.07.2022, 18:11
RE: Finally Arrived! - von CR - 25.07.2022, 19:25
RE: Finally Arrived! - von TrafGib - 26.07.2022, 17:26
Es ist: 21.11.2026, 02:23 Deutsche Übersetzung: MyBB.de, Powered by MyBB 1.8.41, © 2002-2026 MyBB Group.
