SRX 600 2EF - Thomas aus Portland (Oregon USA)
Thomas_S. Offline
29.02.2024, 03:41 (Dieser Beitrag wurde zuletzt bearbeitet: 29.02.2024, 10:10 von CR.)
Hello from Portland, Oregon, on the west coast of USA.
Thanks for allowing me to join your group.
I purchased the pictured 1986 SRX-6 brand new in early 1987. It has long been my favorite motorcycle.
The photo is two years old. The motorcycle has become a bit worn over time and is now undergoing refurbishment. I hope to have it
back on the road within one year and also hope that I may look to the members here for some guidance along the way.
Cheers. ?
Themen: 301
29.02.2024, 09:50 (Dieser Beitrag wurde zuletzt bearbeitet: 29.02.2024, 10:13 von CR.)
Hello Thomas and a warm welcome to the forum. Nice that you have found your way here. The forum is primarily in German so I hope you can read everything with a translation tool. If you have any questions about the SRX, you will be gladly helped here. Pls. start with: You should remount the kickstarter one notch further forward + I would also replace the rear light with a "normal" SRX one.
cheers Chris
  • Thomas_S.
01.03.2024, 02:36
Hi Thomas
Wellcome to the german SRX Community .
The core of us knows knows personally through our annual weekend meetings in summer that we do since 8 years.
There is a lot of competence gathered here.
As chris allready mentioned, the language here is german. Try out how your method of translation works best.
I am allways delighted to see the 2EF maple red color ? Your SRX looks great.
Cheers ?
  • Thomas_S.
Es ist: 05.09.2026, 16:50 Deutsche Übersetzung: MyBB.de, Powered by MyBB 1.8.40, © 2002-2026 MyBB Group.
